[Qgis-developer] Travis timeouts
Matthias Kuhn
matthias at opengis.ch
Thu Apr 7 11:30:05 PDT 2016
On 04/07/2016 05:48 PM, Sandro Santilli wrote:
> On Thu, Apr 07, 2016 at 05:41:00PM +0200, Matthias Kuhn wrote:
>>> Use docker to avoid deps builds ? Not sure if/how travis supports
>>> this. Pretty sure gitlab-ci does (in case you plan to add a mirror
>>> there).
>> Docker is supported but not on container based builds
> Can't you chose the docker to use as the base, for container based
> builds ? What I was suggesting is that you prepare "qgis testing"
> dockers to use as base.
You can build on any docker image but I don't know which dependencies we
could put in there that would reduce build time notably.
The "container based builds" happen on a standard container but have the
advantage that ccache can be persisted between builds (without us taking
care of storage).
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160407/6bba4b20/attachment.sig>
