[Qgis-developer] GRASS issues
Alexander Bruy alexander.bruy at gmail.com
Thu Apr 7 09:51:32 PDT 2016
BTW, which GRASS version affected by all this issues?
I suppose this is GRASS 7, right?
2016-04-07 19:40 GMT+03:00 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Paolo,
> 2016-04-07 19:36 GMT+03:00 Paolo Cavallini <cavallini at faunalia.it>:
>> * Processing asks for a msys folder, and gives an error until the path
>> is removed from config; as Juergen explained, msys is no longer
>> required, so why is Processing asking for it?
> Looking at this right now.
>> * AFAIK now on Windows we only have grass 6: why then we still have a
>> grass (assumed 6) in Processing?
> Already fixed. GRASS 7 is default now, and GRASS 6 can be enabled
> if necessary.
>> * the links in the grass help from Processing do not seem to work.
> If I'm not wrong, support for GRASS help was added only for GRASS 7
> as it is the default GRASS version now.
> Alexander Bruy
Alexander Bruy
