[Qgis-developer] GRASS Plugin Delete vector issue in windows
roy roy
royroge at outlook.com
Wed Apr 20 23:45:49 PDT 2016
Ok thanks Nyall,
so what do you suggest to do about this,
i think it's really quite a issue although it
happens only on windows ...
Il 18/04/2016 12:10, Nyall Dawson ha scritto:
On 18 Apr 2016 19:42, "roy roy" <royroge at outlook.com<mailto:royroge at outlook.com>> wrote:
> Can anyone confirm this issue with GRASS Plugin on:
> Windows 64/32bit with QGIS 2.14.1 and Master
> GRASS 7.0.3 GRASS Plugin
> If you load a vector layer from GRASS DB in QGIS Layers Panel,
> then you remove it from the panel, still it is impossible to
> delete the vector from GRASS DB using the Browser Panel delete function.
I can confirm - this happened to me last week on a Windows build.
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160421/6c3f7022/attachment.html>
