[Qgis-developer] GRASS Plugin Delete vector issue in windows
Nyall Dawson nyall.dawson at gmail.com
Mon Apr 18 03:10:06 PDT 2016
On 18 Apr 2016 19:42, "roy roy" <royroge at outlook.com> wrote:
> Can anyone confirm this issue with GRASS Plugin on:
> Windows 64/32bit with QGIS 2.14.1 and Master
> GRASS 7.0.3 GRASS Plugin
> If you load a vector layer from GRASS DB in QGIS Layers Panel,
> then you remove it from the panel, still it is impossible to
> delete the vector from GRASS DB using the Browser Panel delete function.
> Step to reproduce:
> - Load a vector file in a GRASS mapset using "v.in.ogr",
> - press "View output" to load the vector in QGIS,
> - remove the vector from QGIS Layers Panel
> - In the Browser panel right click the vector and choose "delete"
> the vector file is not deleted (or partially deleted?) and the geometry
is corrupted
> making the file unusable.
> also: if you close QGIS and reopen it (before trying to delete the
> vector file, the file in deleted without errors.
> BTW This does not happens on Linux so it seems specific
> to windows NTFS(?)
I can confirm - this happened to me last week on a Windows build.
Nyall
> Thanks, Roy.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160418/446ae47d/attachment.html>
