[Qgis-developer] [Processing] GDAL - Clip raster by extent : is NODATA param optional ?
René-Luc Dhont rldhont at gmail.com
Mon Apr 25 08:31:56 PDT 2016
Hi all,
I encountered some trouble to integrate 'GDAL - Clip raster by extent'
in a model.
The NODATA param is described as 'Nodata value, leave blank to take the
nodata value from input' and it is not optional. There is no problem if
the algorithm is executed alone. But when we integrated 'GDAL - Clip
raster by extent' in a model with an empty value for NODATA, because the
field is empty, the algorithm can't be added.
The easy way to fix it is to decalre NODATA param as optional. What do
you think about it ?
Do you know other potential optional parameters ?
René-Luc
