[Qgis-developer] [Processing] GDAL - Clip raster by extent : is NODATA param optional ?
Victor Olaya volayaf at gmail.com
Mon Apr 25 09:24:53 PDT 2016
There should be no problem declaring it as optional (it is actually
optional, so it fixed the decalration)
What surprises me a bit is that when running from the toolbox, an
empty string is accepted as a valid value...if it is not optional, it
should complain
Anyway, that's a different thing :-) Feel free to update the paramter
in the algorithm to fix that
Thanks!
2016-04-25 17:31 GMT+02:00 René-Luc Dhont <rldhont at gmail.com>:
> Hi all,
> I encountered some trouble to integrate 'GDAL - Clip raster by extent' in a
> model.
> The NODATA param is described as 'Nodata value, leave blank to take the
> nodata value from input' and it is not optional. There is no problem if the
> algorithm is executed alone. But when we integrated 'GDAL - Clip raster by
> extent' in a model with an empty value for NODATA, because the field is
> empty, the algorithm can't be added.
> The easy way to fix it is to decalre NODATA param as optional. What do you
> think about it ?
> Do you know other potential optional parameters ?
> René-Luc
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
