[Qgis-developer] [Processing] GDAL - Clip raster by extent : is NODATA param optional ?
Giovanni Manghi giovanni.manghi at gmail.com
Mon Apr 25 13:29:52 PDT 2016
> Hi all,
> I encountered some trouble to integrate 'GDAL - Clip raster by extent'
> in a model.
> The NODATA param is described as 'Nodata value, leave blank to take the
> nodata value from input' and it is not optional. There is no problem if
> the algorithm is executed alone. But when we integrated 'GDAL - Clip
> raster by extent' in a model with an empty value for NODATA, because the
> field is empty, the algorithm can't be added.
> The easy way to fix it is to decalre NODATA param as optional. What do
> you think about it ?
> Do you know other potential optional parameters ?
> René-Luc
I made a PR to fix it.
By the way, recently in this GDAL gdal_translate (used to clip by
extent) has been added the parameter
-wo OPTIMIZE_SIZE=TRUE
but this is not documented
http://www.gdal.org/gdal_translate.html
and in fact the command run from Processing fails on master because of it.
Can I remove it?
cheers
-- G --
