[Qgis-developer] Report 10 - QGIS Resources Sharing Tools
Akbar Gumbira
akbargumbira at gmail.com
Mon Aug 1 02:13:40 PDT 2016
Hi Matthias,
> I guess support for relative URLs should be trivial and make the
> repositories more portable. And as far as I can see it should be
> possible to have relative and absolute paths side-by-side, no?
If it's a matter of portability, users can still put the metadata inside
the repository itself (if they put the repository in a directory based e.g
git/local file system). It's just that they need to explicitly put the
metadata URI in the settings when adding a repository.
If users want to make a zip collections, they need to put the metadata
somewhere else outside the zip. I agree with Ale though that most users
probably prefer this, they can just put a zip and the metadata file in
dropbox or google drive for example.
Cheers
On Mon, Aug 1, 2016 at 10:56 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi
> > In general, I feels that this is a better approach also in the sense
> > that "explicit is better than implicit", we provide explicit URIs
> > instead of delegate guessing them to the software layer.
> Regards
> Matthias
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
*Akbar Gumbira *
*www.akbargumbira.com <http://www.akbargumbira.com>*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160801/6bd49696/attachment-0001.html>
