[Qgis-developer] Report 10 - QGIS Resources Sharing Tools
Akbar Gumbira
akbargumbira at gmail.com
Mon Aug 1 02:35:46 PDT 2016
Hi Matthias,
I think I missed your point before. I think I will add a flag in the
metadata that users need to put, to state whether the repository is using
the same protocol as the metadata or not. This way it could be more
portable to use the repository in different protocol. For example users can
clone a repository from git and use that repository in the local without
having to change the metadata file itself.
Cheers
On Mon, Aug 1, 2016 at 11:13 AM, Akbar Gumbira <akbargumbira at gmail.com>
wrote:
> Hi Matthias,
>> I guess support for relative URLs should be trivial and make the
>> repositories more portable. And as far as I can see it should be
>> possible to have relative and absolute paths side-by-side, no?
> If it's a matter of portability, users can still put the metadata inside
> the repository itself (if they put the repository in a directory based e.g
> git/local file system). It's just that they need to explicitly put the
> metadata URI in the settings when adding a repository.
> If users want to make a zip collections, they need to put the metadata
> somewhere else outside the zip. I agree with Ale though that most users
> probably prefer this, they can just put a zip and the metadata file in
> dropbox or google drive for example.
> Cheers
> On Mon, Aug 1, 2016 at 10:56 AM, Matthias Kuhn <matthias at opengis.ch>
> wrote:
>> Hi
>> > In general, I feels that this is a better approach also in the sense
>> > that "explicit is better than implicit", we provide explicit URIs
>> > instead of delegate guessing them to the software layer.
>> Regards
>> Matthias
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> *Akbar Gumbira *
> *www.akbargumbira.com <http://www.akbargumbira.com>*
*Akbar Gumbira *
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160801/973ee8c6/attachment.html>
