[Qgis-developer] Adding SQL provider to QGIS
Jürgen E. Fischer
jef at norbit.de
Tue Aug 2 10:11:51 PDT 2016
Hi David,
On Tue, 02. Aug 2016 at 11:59:57 -0400, David Adler wrote:
> We developed DB2 support for QGIS using the ODBC driver that is
> built in to QGIS/Qt for Windows. But the ODBC driver isn't built in
> on other platforms and using ODBC on other platforms is sketchy.
> Is it possible to build and use the Qt DB2 driver with QGIS and is
> there any documentation on how to do this?
Does the Qt DB2 driver have third party dependencies?
For the Oracle provider we have a modified QOCI driver that is built with QGIS
when it's dependencies are available, but that usually not the case on
platforms other than (osgeo4)Windows either.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160802/3b088f0d/attachment.sig>
