[Qgis-developer] DB2 Driver for QGIS
David Adler
dadler at adtechgeospatial.com
Tue Aug 2 12:43:35 PDT 2016
On 8/2/2016 3:00 PM, qgis-developer-request at lists.osgeo.org wrote:
> Date: Tue, 2 Aug 2016 19:11:51 +0200 From: Jürgen E. Fischer
> <jef at norbit.de> To: QGIS Developer Mailing List
> <qgis-developer at lists.osgeo.org> Subject: Re: [Qgis-developer] Adding
> SQL provider to QGIS Message-ID: <20160802171151.GA17900 at norbit.de>
> Content-Type: text/plain; charset="iso-8859-1" Hi David, On Tue, 02.
> Aug 2016 at 11:59:57 -0400, David Adler wrote:
>> >We developed DB2 support for QGIS using the ODBC driver that is
>> >built in to QGIS/Qt for Windows. But the ODBC driver isn't built in
>> >on other platforms and using ODBC on other platforms is sketchy.
>> >Is it possible to build and use the Qt DB2 driver with QGIS and is
>> >there any documentation on how to do this?
> Does the Qt DB2 driver have third party dependencies?
Yes, probably similar to Oracle.
> For the Oracle provider we have a modified QOCI driver that is built with QGIS
> when it's dependencies are available, but that usually not the case on
> platforms other than (osgeo4)Windows either.
How do you build the driver? Does it end up being a new QGIS executable
or does it just create an additional DLL with the QOCI driver?
We want to avoid requiring end-users to build complete QGIS from source
- it is hard enough for experienced developers to get this to work ;-)
We've managed to build the Qt QDB2 driver DLL but have not been
successful in having a Qt application load it.
Regards,
David
> Jürgen
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160802/d678938e/attachment.html>
