[Qgis-developer] [QGIS] Using pixel as default units while defining layer style
ABALAIN, Pierre-Yves
pierreyves.abalain at capgemini.com
Mon Aug 8 08:07:02 PDT 2016
Hello,
I'm importing SLD in QGis Essen, and I note that unit for parameter (thickness for example) in setting layer styles are always in millimeter.
But the application I used to export my SLD uses pixel as unit.
Is there a parameter in QGis that allow me to change this default unit ?
Regards.
P.Y. Abalain
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160808/40d5cf37/attachment.html>
