[Qgis-developer] [QGIS] Using pixel as default units while defining layer style
Luigi Pirelli luipir at gmail.com
Tue Aug 9 02:42:01 PDT 2016
a recend discussion about this issue
http://osgeo-org.1560.x6.nabble.com/SLD-export-not-compliant-due-to-unit-attribute-in-the-root-element-td5277807.html
regards
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 8 August 2016 at 17:07, ABALAIN, Pierre-Yves
<pierreyves.abalain at capgemini.com> wrote:
> Hello,
> I’m importing SLD in QGis Essen, and I note that unit for parameter
> (thickness for example) in setting layer styles are always in millimeter.
> But the application I used to export my SLD uses pixel as unit.
> Is there a parameter in QGis that allow me to change this default unit ?
> Regards.
> P.Y. Abalain
> This message contains information that may be privileged or confidential and
> is the property of the Capgemini Group. It is intended only for the person
> to whom it is addressed. If you are not the intended recipient, you are not
> authorized to read, print, retain, copy, disseminate, distribute, or use
> this message or any part thereof. If you receive this message in error,
> please notify the sender immediately and delete all copies of this message.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
