[Qgis-developer] [Qgis-user] QGIS Crash Message
Richard Duivenvoorde rdmailings at duif.net
Tue Aug 9 12:32:31 PDT 2016
On 09-08-16 21:13, Tim Sutton wrote:
> Using a unified configuration system on all platforms would be nice...
>> I think having an option to use the registry on windows would be best
>> then. As Régis also stated, in some enterprise environments it as
>> apperently not doable to use the not-registry option...
>> Then we have best of both worlds?
> Probably we can add a setting in QGIS to indicate whether settings
> should be in native or ini style format [1]. Of course that is a bit
> paradoxical since it will need to read the settings to get the setting
> for reading the settings .... :-)
I was more thinking like: we make ini file settings default for all OS's
(instead of taking the OS-specific defaults).
And make a startup parameter (or environment variable) so you can start
using QGIS with your OS-specific setting, if you really want?
Regards,
Richard
