[Qgis-developer] [Qgis-user] QGIS Crash Message
Tim Sutton tim at kartoza.com
Tue Aug 9 13:18:01 PDT 2016
Hi
> On 09 Aug 2016, at 9:32 PM, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> On 09-08-16 21:13, Tim Sutton wrote:
>> Using a unified configuration system on all platforms would be nice...
>>> I think having an option to use the registry on windows would be best
>>> then. As Régis also stated, in some enterprise environments it as
>>> apperently not doable to use the not-registry option...
>>> Then we have best of both worlds?
>> Probably we can add a setting in QGIS to indicate whether settings
>> should be in native or ini style format [1]. Of course that is a bit
>> paradoxical since it will need to read the settings to get the setting
>> for reading the settings .... :-)
> I was more thinking like: we make ini file settings default for all OS's
> (instead of taking the OS-specific defaults).
> And make a startup parameter (or environment variable) so you can start
> using QGIS with your OS-specific setting, if you really want?\
Yeah or a simple text file in the QGIS share dir which contains the preferred option.
Regards
Tim
> Regards,
> Richard
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160809/375093f5/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160809/375093f5/attachment-0001.jpg>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160809/375093f5/attachment-0001.sig>
