[Qgis-developer] Windows builds of the master branch
Jürgen E. Fischer
jef at norbit.de
Wed Aug 10 01:11:58 PDT 2016
Hi Denis,
On Wed, 10. Aug 2016 at 09:58:13 +0200, Denis Rouzaud wrote:
> > No. master will eventually become Qt5/Python 3 only. So packaging master
> > would only work until that switch is done - and after that Qt5/Py3 is
> > required that is not yet in OSGeo4W.
> Is there any plan regarding this?
> Are you in charge of packaging Qt5/Py3 in osgeo?
osgeo4w, yes.
I did build Qt 5.7 - but only started with the packaging, no python3, no PyQt5,
no QGIS based not it.
> Do you have an idea about the time frame?
Not really. After the Qt4 support is removed.
> I am wondering how we should deal with plugin compatibility.
This is a general question, that is not tied to OSGeo4W. The plugin manager
and the plugins site will have to deal with this.
> In other words, if we wait a bit of time before making packages with
> Qt5/Py3 available, shall we have a description for plugins to tell with
> wich Python version they're compatible?
QGIS3 will be Qt5/Py3. So anything available for >=3 (and >=2.99 once we
remove Qt4 support from master) will have to work with it. So it might not be
necessary to address that separately.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160810/36af829c/attachment-0001.sig>
