[Qgis-developer] Windows builds of the master branch
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Aug 10 00:58:13 PDT 2016
Hi Jürgen,
On 08/10/2016 09:51 AM, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Wed, 10. Aug 2016 at 08:26:52 +0200, Neumann, Andreas wrote:
>> A question probably for Jürgen.
>> In the OSGeo4W distribution - is there a way to get access to nightlies
>> from the "master" branch? I know that these builds could break regularly
>> - nevertheless I think it would be useful to have.
> No. master will eventually become Qt5/Python 3 only. So packaging master
> would only work until that switch is done - and after that Qt5/Py3 is required
> that is not yet in OSGeo4W.
Is there any plan regarding this?
Are you in charge of packaging Qt5/Py3 in osgeo?
Do you have an idea about the time frame?
I am wondering how we should deal with plugin compatibility.
In other words, if we wait a bit of time before making packages with
Qt5/Py3 available, shall we have a description for plugins to tell with
wich Python version they're compatible?
Thanks,
Denis
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160810/cf5f3069/attachment.sig>
