[Qgis-developer] OpenLayers Plugin - feature request
Arne Wichmann
aw at saar.de
Sat Aug 13 03:11:32 PDT 2016
begin quotation from Bernd Vogelgesang (in <op.yltvgnk0l2i25i at vogelbe-esprimo-p2560>):
> have a look at the QuickMapServices-plugin.
> There are already some Stamen backgrounds available.
> Maybe the one you look for is there too. Have also a look at Settings/More
> services/Get contributed pack
> As far as I know, OpenLayers will be replaced by QuickMapServices
Thanks, it helped a bit - it still does not have Stamen terrain-background
or something comparable, but it has two other maps I might use eventually.
I might try to add Stamen terrain-background when I get around to it -= but
I expect this will take some months.
cu
AW
[...] If you don't want to be restricted, don't agree to it. If you are
coerced, comply as much as you must to protect yourself, just don't support
it. Noone can free you but yourself. (crag, on Debian Planet)
Arne Wichmann (aw at saar.de)
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160813/5c730498/attachment.sig>
