[Qgis-developer] Qt 5.5 Conversion from QVariant to QString is broken for double and float values
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Aug 15 06:45:32 PDT 2016
Hi all,
While looking at failing tests on Qt5, it seems that QgsJSONUtils test
is failing due to a regression on Qt 5.5.
values [0].
It seems to have been fixed in Qt 5.7
Especially QgsJSONUtils.encodeValue(5.9) returns '5.9000000000000004'.
What would you suggest?
* Don't care and discard failing test with Qt 5.5 - 5.6? (is this really
an issue?)
* Use a custom toString method to fix this?
* Bump min Qt version to 5.7?
Cheers,
Denis
[0] https://bugreports.qt.io/browse/QTBUG-47192
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160815/f886a5bf/attachment.html>
