[Qgis-developer] Problems with using QGIS Custom Widgets
Casper Børgesen (CABO)
CABO at NIRAS.DK
Thu Aug 18 01:13:53 PDT 2016
Hi Calvin
It does. Thanks a lot!
Regards, Casper
From: C Hamilton [mailto:adenaculture at gmail.com]
Sent: 17. august 2016 16:47
To: Casper Børgesen (CABO)
Cc: qgis-developer
Subject: Re: [Qgis-developer] Problems with using QGIS Custom Widgets
Yes I did. When you save the file it uses the C++ header so in my case it had the following:
<customwidgets>
<customwidget>
<class>QgsColorButtonV2</class>
<extends>QToolButton</extends>
<header>qgscolorbuttonv2.h</header>
</customwidget>
</customwidgets>
You need to replace qgscolorbutton2.h with the PyQT/PyGIS gui module. In this case it is:
<customwidgets>
<customwidget>
<header>qgis.gui</header>
</customwidget>
</customwidgets>
I think this works for all of the custom QGIS widgets. Unfortunately, every time you save using Qt Designer it overwrites qgis.gui and you have to manually go put it back in.
I hope this helps.
Calvin
On Wed, Aug 17, 2016 at 10:09 AM, Casper Børgesen (CABO) <CABO at niras.dk<mailto:CABO at niras.dk>> wrote:
Hi Calvin
I’m facing the same problem and before I go home I just wanted to ask if you found a solution to this problem?
Regards, Casper
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160818/37df2e07/attachment.html>
