[Qgis-developer] JSON parsing
Jürgen E. Fischer
jef at norbit.de
Fri Aug 19 02:08:48 PDT 2016
Hi Patrick,
On Fri, 19. Aug 2016 at 10:57:19 +0200, Patrick Valsecchi wrote:
> Now, can I add qjson-dev as dependency to the Travis build in master?
> For QT5, there is a JSON parser included, so I could #ifdef the hell out of
> it and use the Qt parser if in Qt5.
The arcgis stuff will be ported to the Qt5 parser and Qt4 support will
disappear in master. So adding qjson will only help for now.
And there's also possibility to parse json without qjson in Qt4 (used in the
wms provider to parse GetFeatureInfo responses in json).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160819/511f9872/attachment.sig>
