[Qgis-developer] QEP about Multimap support for QGIS
Régis Haubourg
regis.haubourg at gmail.com
Mon Aug 29 02:34:01 PDT 2016
This is a long awaited feature, partially fullfilled by DockableMirrorMap
and Auxiliary windows plugins. I'm glad someone reactivates work in that
area :)
Keeping it simple in API and in UX are the main obstacles. QGIS was seen as
a user friendly GIS because there was no hard multimap ergonomy. We must
find our way to have it pretty simple in a user point of view. Composer's
redesign into Layout is also deeply impacted.
+1 for a QEP, there are so much changes implied in that, UX, API, but also
map and layer presets that currently allow the multimap workflow.
Cheers
Régis
2016-08-29 10:59 GMT+02:00 Geo DrinX <geodrinx at gmail.com>:
> Alvaro,
> as I can see in github repository, at:
> https://github.com/qgis/QGIS/compare/master...ahuarte47:
> Feature_MultimapView
> As I can see, your MultimapView will change many calls, adding
> parameters.
> I suppose therefore that almost all plugins will have to take account of
> these new parameters and need to be changed, it is no longer compatible.
> We can not adopt a "soft" technique, in the sense that new parameters can be
> optional ?
> Thank you
> Roberto
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Régis Haubourg
Attention, changement d'adresse mail!
Mon adresse principale devient désormais regis.haubourg at gmail.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160829/e79bde74/attachment.html>
