[Qgis-developer] Decoupling core/data and GUI part of widgets in 3.0
Nyall Dawson
nyall.dawson at gmail.com
Wed Aug 31 03:41:47 PDT 2016
On 31 August 2016 at 16:56, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi,
> I've already got some ideas because it affects QField (where I'm about
> to drop the whole gui lib) as well.
> Implementing this in QGIS instead of QField is much preferred.
> From a technical perspective, I would propose to use a tree-like
> structure based on QVariants.
> They've got all it takes for this:
> QVariantMap can handle tree structures of key value pairs (for XML child
> nodes), a key "__attributes__" can be added to save the XML element
> attributes into.
> This way, the information can be read without knowledge about a
> particular widget's implementation details and is available directly
> from core. The widgets (or whatever part) can add the semantics on top
> in their own library.
Just to clarify - are you proposing that only a map of widget
configuration is moved to core? I'd say the representValue function
for each widget should also should be moved across, otherwise we'll
end up with multiple code paths reimplementing the logic from each
widget + plugins having to redo this themselves.
> So that's the inoffical QEP, I'd say we skip the official part.
Fine by me - a QEP would have just been a way to get yourself and
Denis to approve a design for this :)
Nyall
> Matthias
> On 08/31/2016 08:48 AM, Richard Duivenvoorde wrote:
>> +1 from me too
>> As a project we should really take the opportunity of a 3.0 branch to
>> review this kind of architectural cleanups and focus on a healthy code
>> base more then on new features for the .0 version, in my opinion.
>> best off course if core dev's take the lead in this
>> Regards,
>> Richard
>> On 31-08-16 08:37, Nathan Woodrow wrote:
>>> I'm a big +1 on that. I will add my notes on a QEP if one is opened
>>> (Hopefully I can be a bit more active in the project after a bit of a break)
>>> - Nathan
>>> On Wed, Aug 31, 2016 at 4:29 PM, Neumann, Andreas <a.neumann at carto.net
>>> <mailto:a.neumann at carto.net>> wrote:
>>> Hi all, Hi Nyall, Matthias and Denis,
>>> After some discussion with Nyall we stumbled again over the
>>> inconvenience that widgets in QGIS mix data (core) and GUI part.
>>> This effects many places in QGIS where you want to address the
>>> display value of a widget instead of the raw value: QGIS Server
>>> (e.g. GetFeatureInfo Requests), Print Composer, Labels, Save to
>>> Spreadsheet with human readable values, and many more.
>>> So before people are introducing more and more widgets (which is
>>> nice) I would suggest to first improve our widget infrastructure for
>>> QGIS 3.0 to decouple the Core/data part from the GUI part, which
>>> would allow code to access all widget configuration and
>>> properties without having to deal with the GUI part of the widget.
>>> Nyall mentioned that the symbology rendering separates this nicely,
>>> but the attribute widgets do not.
>>> Nyall suggested to do a QEP for that to discuss the implications and
>>> how this can be cleanly designed.
>>> Matthias - since you are "the widget guy" - do you want to take a
>>> lead on this QEP? Or should I ask Nyall?
>>> Thanks,
>>> Andreas
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
