[Qgis-developer] No plugins today?
Richard Duivenvoorde rdmailings at duif.net
Wed Aug 31 21:59:20 PDT 2016
On 31-08-16 15:02, Kari Salovaara wrote:
> Hi,
> On win64 latest Master version gives me error:
> Error reading repository: QGIS Virallinen Liitännäisten Etäkirjasto
> Server response is 200 OK, but doesn't contain plugin metatada. This is
> most likely caused by a proxy or a wrong repository URL. You can
> configure proxy settings in QGIS options.
> Annoying ....
> Boundless repo OK so probably not program error.
Hi Kari,
is it still a problem? Because for master the url that is used is:
https://plugins.qgis.org/plugins/plugins.xml?qgis=2.17
(for master_2)
https://plugins.qgis.org/plugins/plugins.xml?qgis=2.99
(for real master)
which now work both
(could be a timeout? Because if I'm correct the master ones are not cached)
Regards,
Richard
