[Qgis-developer] how to turn my plugin into a processing subplugin
Médéric Ribreux mederic.ribreux at medspx.fr
Thu Dec 1 12:47:25 PST 2016
Le 2016-11-28 16:20, Julie Pierson a écrit :
> Hi all,
> I would like to answer this issue for my plugin :
> https://github.com/UMR-PASSAGES/DissolveWithStats/issues/2, and turn
> it into a processing subplugin. I read this :
> https://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/processing.html,
> but I'm still not sure how to go on.
> I'm guessing that my script will be accessible from the Scripts/Tools
> part of the processing toolbox. But I don't understand :
> - where these scripts are hosted, and how do I submit it
> - where do I start ? Should I just make  a new version of my plugin
> without the GUI ?
> Sorry if the answers are obvious !
> Thanks,
> Julie.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Hello,
I think that you can first try to convert your plugin to a Processing
Python script as stated here:
https://docs.qgis.org/testing/en/docs/user_manual/processing/scripts.html
When you create a Processing Python script from the dedicated dialog, it
is stored into your ~/.qgis3/processing/script/ directory.
To fill the script code, you will have to extract the "algorithm" part
of your plugin (the things that do the stats or the dissolve part which
seems to be stored into 'dissolve_stats_dialog.py') and put it into a
Python script.
For input/output, just use the dedicated "comments" syntax at the
beginning of the script:
     ##myvector=vector
defines an input vector which will be available in myvector Python
variable.
Once inputs and outputs are defined, there is no need to deal with
dialogs to open/choose files, just use the "comments" variables and
Processing will build the dialogs for you.
The script will be processed by Processing as is: the code will be
interpreted as a Python script. You can add as many classes/functions
you'd like into the script. Don't use the `if __name__ == '__main__'`
Python syntax for the main loop. I think it is not interpreted correctly
by Processing (not 100% sure though).
Once your plugin is converted, you can make a PR to
https://github.com/qgis/QGIS-Processing which is the repository for 'Get
models from on-line scripts collection' Processing dialog box and it
will become available to anybody.
Cheers,
Médéric RIBREUX
https://medspx.fr
