[Qgis-developer] QGIS Custom Widget in Qt Designer
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Wed Dec  7 00:40:19 PST 2016
On 12/07/2016 09:13 AM, matteo wrote:
> HI Denis,
> thanks for the answer..
>> Having the error on master sounds correct, since QgsColorButtonV2 really
>> doesn't exist anymore (replaced by QgscolorButton [0]).
> ok got it.. anyway, I have the same error also with QgsDataDefined
> button and all the other Qgs widgets..
>> As I wrote already in the topic, issues seem to arise when using
>> uic.loadUi. Are you using this approach?
> yep..
> uic.loadUi(os.path.join(os.path.dirname(__file__), 'prova_dialog_base.ui'))
>> Personally, I use pyuic without any issue (you just need to be sure that
>> you have qgis in your python path, which requires attention in your case
>> since you don't install qgis).
> ok maybe we got the guilty here (and that's me as always.. :) )
> how can I export qgis in my python path? Something like that?
> export QGIS_INSTALL_PREFIX="/home/matteo/lavori/QGIS/build-qgis2/output/"
> export PYTHONPATH=$QGIS_INSTALL_PREFIX/python/qgis
> export PYTHONPATH=$PYTHONPATH:/home/$USER/.qgis2/python/plugins
PYTHONPATH=$PYTHONPATH:YOURQGISBUILD/output/python should do the job.
