[Qgis-developer] QGIS Custom Widget in Qt Designer
Denis Rouzaud denis.rouzaud at gmail.com
Wed Dec 7 01:58:08 PST 2016
Hi Matteo,
The file is not present simply because you did not install QGIS.
See here https://github.com/qgis/QGIS/blob/master/python/CMakeLists.txt#L287
Having it documented somewhere would be nice:
* Approach when installing
* Without installing: were to put libqgis_customwidget and
qgis_customwidgets.py, how to run pyuic.
Cheers,
Denis
On 12/07/2016 10:41 AM, matteo wrote:
> Hold on.. I should have manage it..
> I discovered that my machine was missing the file
> in the folder
> /usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/
> in another machine I found that file and I copied it in the right folder
> (the above one) and now it seems working, that is the plugin with the
> custom widget is now correctly loaded without any more issues..
> So many thanks Denis for the assistance..
> My question is now.. why was that file missing in the folder?
> In the other machine I ran Ubuntu and I was used to compile QGIS with
> debian rules.
> In this new machine I compile QGIS with make and run it directly from
> the output folder (so QGIS has never been installed with repository
> packages and/or deb files, don't know if this could be related to the
> problem)
> I have some confusion on my mind..
> If this is worth I can put this solution (if you think it is a solution
> and not a workaround) somewhere in the website or another place so that
> other people facing the same problem could solve the issue.
> Many many thanks to all
> Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161207/8ca53c55/attachment-0001.html>
