[Qgis-developer] QGIS Custom Widget in Qt Designer
Marco Bernasocchi
marco at opengis.ch
Wed Dec 7 03:51:53 PST 2016
Salut Denis,
I'm a bit lost, I see in plugins like the resources sharing tool [0]
<customwidgets>
<customwidget>
<class>QWebView</class>
<extends>QWidget</extends>
<header>QtWebKitWidgets/QWebView</header>
</customwidget>
</customwidgets>
and when I install the plugin I see:
This plugin is broken
No module named QtWebKitWidgets.QWebView
this plugins also use the uic.loadUi approach
I've qgis installed from packages and also self build:
marco at placebo:~/dev/QGIS/master/python/custom_widgets$ locate
libqgis_customwidgets.so
/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqgis_customwidgets.so
/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqgis_customwidgets.so.2.18.1
qgis_customwidgets.py
/home/marco/dev/QGIS/master/python/custom_widgets/qgis_customwidgets.py
/home/marco/gis_data/pacsafe/QGIS/python/custom_widgets/qgis_customwidgets.py
/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/qgis_customwidgets.py
/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/qgis_customwidgets.pyc
Am I missing some magic somewhere? QtWebKitWidgets exists only from Qt5.
in Qt4 it should still be QtwebKit.
ciao
Marco
[0]
https://github.com/akbargumbira/qgis_resources_sharing/blob/master/resource_sharing/gui/ui/resource_sharing_dialog_base.ui#L598
On 07.12.2016 22:58, Denis Rouzaud wrote:
> Hi Matteo,
> The file is not present simply because you did not install QGIS.
> See here https://github.com/qgis/QGIS/blob/master/python/CMakeLists.txt#L287
> Having it documented somewhere would be nice:
> * Approach when installing
> * Without installing: were to put libqgis_customwidget and
> qgis_customwidgets.py, how to run pyuic.
> Cheers,
> Denis
> On 12/07/2016 10:41 AM, matteo wrote:
>> Hold on.. I should have manage it..
>> I discovered that my machine was missing the file
>> in the folder
>> in another machine I found that file and I copied it in the right folder
>> (the above one) and now it seems working, that is the plugin with the
>> custom widget is now correctly loaded without any more issues..
>> So many thanks Denis for the assistance..
>> My question is now.. why was that file missing in the folder?
>> In the other machine I ran Ubuntu and I was used to compile QGIS with
>> debian rules.
>> In this new machine I compile QGIS with make and run it directly from
>> the output folder (so QGIS has never been installed with repository
>> packages and/or deb files, don't know if this could be related to the
>> problem)
>> I have some confusion on my mind..
>> If this is worth I can put this solution (if you think it is a solution
>> and not a workaround) somewhere in the website or another place so that
>> other people facing the same problem could solve the issue.
>> Many many thanks to all
>> Matteo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Marco Bernasocchi
OPENGIS.ch - berna.io - 27summits.ch
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161208/2d96b1f6/attachment.sig>
