[Qgis-developer] QGIS Custom Widget in Qt Designer
Rouzaud Denis
denis.rouzaud at gmail.com
Wed Dec 7 05:16:55 PST 2016
Hi Marco,
This doesn’t sound like a QGIS custom widget issue since QWebView is not related to QGIS.
It seems that QWebView is well defined in PyQt4 compatibility layer [0].
The issue is probably that you try to run system uic instead of qgis.PyQt.uic.
This make me thunk of the reply to Matteo as well….try to run qgis.PyQt.uic instead of uic
I hope this helps
Denis
[0] https://github.com/qgis/QGIS/blob/release-2_18/python/PyQt/PyQt4/QtWebKitWidgets.py#L32 <https://github.com/qgis/QGIS/blob/release-2_18/python/PyQt/PyQt4/QtWebKitWidgets.py#L32>
> On 7 Dec 2016, at 12:51, Marco Bernasocchi <marco at opengis.ch> wrote:
> Salut Denis,
> I'm a bit lost, I see in plugins like the resources sharing tool [0]
> <customwidgets>
> <customwidget>
> <class>QWebView</class>
> <extends>QWidget</extends>
> <header>QtWebKitWidgets/QWebView</header>
> </customwidget>
> </customwidgets>
> and when I install the plugin I see:
> This plugin is broken
> No module named QtWebKitWidgets.QWebView
> this plugins also use the uic.loadUi approach
> I've qgis installed from packages and also self build:
> marco at placebo:~/dev/QGIS/master/python/custom_widgets$ locate
> libqgis_customwidgets.so
> /usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqgis_customwidgets.so
> /usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqgis_customwidgets.so.2.18.1
> qgis_customwidgets.py
> /home/marco/dev/QGIS/master/python/custom_widgets/qgis_customwidgets.py
> /home/marco/gis_data/pacsafe/QGIS/python/custom_widgets/qgis_customwidgets.py
> /usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/qgis_customwidgets.py
> /usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/qgis_customwidgets.pyc
> Am I missing some magic somewhere? QtWebKitWidgets exists only from Qt5.
> in Qt4 it should still be QtwebKit.
> ciao
> Marco
> [0]
> https://github.com/akbargumbira/qgis_resources_sharing/blob/master/resource_sharing/gui/ui/resource_sharing_dialog_base.ui#L598
> On 07.12.2016 22:58, Denis Rouzaud wrote:
>> Hi Matteo,
>> The file is not present simply because you did not install QGIS.
>> See here https://github.com/qgis/QGIS/blob/master/python/CMakeLists.txt#L287
>> Having it documented somewhere would be nice:
>> * Approach when installing
>> * Without installing: were to put libqgis_customwidget and
>> qgis_customwidgets.py, how to run pyuic.
>> Cheers,
>> Denis
>> On 12/07/2016 10:41 AM, matteo wrote:
>>> Hold on.. I should have manage it..
>>> I discovered that my machine was missing the file
>>> in the folder
>>> in another machine I found that file and I copied it in the right folder
>>> (the above one) and now it seems working, that is the plugin with the
>>> custom widget is now correctly loaded without any more issues..
>>> So many thanks Denis for the assistance..
>>> My question is now.. why was that file missing in the folder?
>>> In the other machine I ran Ubuntu and I was used to compile QGIS with
>>> debian rules.
>>> In this new machine I compile QGIS with make and run it directly from
>>> the output folder (so QGIS has never been installed with repository
>>> packages and/or deb files, don't know if this could be related to the
>>> problem)
>>> I have some confusion on my mind..
>>> If this is worth I can put this solution (if you think it is a solution
>>> and not a workaround) somewhere in the website or another place so that
>>> other people facing the same problem could solve the issue.
>>> Many many thanks to all
>>> Matteo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Marco Bernasocchi
> OPENGIS.ch - berna.io - 27summits.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161207/0c27f79a/attachment-0001.html>
