[Qgis-developer] Plugin requirements
Luigi Pirelli luipir at gmail.com
Wed Dec 7 06:22:10 PST 2016
Hi Xavier
1) pip can be installed on OSGeo4W (many references on the gis stack
exchange and on the web)
2) paver do nothing other than creating python eggs or now you can use
wheel format, then setting pythonpath starting the plugin allow you to
load module from local modules... paver is a utility to simplify
packaging
cheers
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 7 December 2016 at 10:44, Xavier Barnada <xbarnada at gisce.net> wrote:
> Hi Alessandro,
> Thank you for the example, I will study paver to see how it works
> Cheers
> 2016-12-07 9:49 GMT+01:00 Alessandro Pasotti <apasotti at gmail.com>:
>> On Wed, Dec 7, 2016 at 9:43 AM, Xavier Barnada <xbarnada at gisce.net> wrote:
>>> Hi all,
>>> I been working on a plugin that uses another python requirements like
>>> lxml.
>>> The problem it's that I solved the requirements problem on Linux calling
>>> pip command but this don't work on QGIS with Windows because Windows don't
>>> incorporate python or pip.
>>> In my opinion QGIS API should provide a way to install packages but i
>>> supose that it's not so easy as I imagine.
>>> How do you use to solve this problem?  There is any example of it?  I
>>> searched it on the documentation and don't appear any reference about how to
>>> do it.
>>> Best reggards
>>> Xavier Barnada
>> Hi Xavier!
>> We've considered adding a mechanism for plugin dependencies, (I've
>> recently added a metadata for that purpose) but this seems a bit difficult
>> to work cross-platform, BTW I'd be very happy to see some efforts in that
>> area.
>> What we normally do is to package and ship dependencies with the plugin
>> itself, you can have a look to this example:
>> https://github.com/boundlessgeo/qgis-geoserver-plugin/blob/master/pavement.py#L48
>> Cheers.
>> Alessandro Pasotti
>> w3:   www.itopen.it
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
