[Qgis-developer] Today I almost build QGIS on Linux... but it fails
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Dec 14 02:51:36 PST 2016
You don’t have to run “make install” and simply run QGIS after “make” :
If you cd to QGIS_BUILD_DIR/output/bin/ and run ./qgis
Cheers
Saber
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of DelazJ
Sent: 14 December 2016 10:40
To: qgis-developer
Subject: [Qgis-developer] Today I almost build QGIS on Linux... but it fails
Disclaimer: I'm a long-term Windows user who is learning Linux. And I'm not a developer so be patient.
Before I pulled a request to master branch I decided this time to build QGIS and check my changes. I often heard people say "Use Linux; it's so easy to do that". And while a year (or more) ago I completely fail to understand which version of tools I should install to do that on Windows (7 or 8), this time it looks very straightforward.
I followed instructions at http://htmlpreview.github.io/?https://raw.githubusercontent.com/qgis/QGIS/master/doc/INSTALL.html
(note that it should be updated as there still is:
- a section entitled Qt4 <https://htmlpreview.github.io/?https://raw.githubusercontent.com/qgis/QGIS/master/doc/INSTALL.html#toc4> while its content is all about Qt5 and, Qt4 has nothing to do with QGIS 3 if I'm not wrong
- a section entitled Qt5 <https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc12> which warns you about using Qt5)
So, I followed these instructions, regardless Qt4 title:
- create the same folders at the same places
- run "ccmake .." indicate the $home/apps folder as destination folder for the application (CMAKE_INSTALL_PREFIX)
- run "make"
- and then run "make install", showing many lines that point to my apps dir. I get a failure due to right access to some folder (I don't know why). So I run "sudo make install" which went till the end with no failure (that i can see)
But when all this finishes tens of minutes later, my home/apps dir remains EMPTY. No QGIS to launch!
If someone has an idea where I should investigate thanks very much. Or if you need me provide more information, let me know...
Thanks,
Harrissou
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161214/d272544e/attachment.html>
