[Qgis-developer] Today I almost build QGIS on Linux... but it	fails
    DelazJ
    delazj at gmail.com
    Wed Dec 14 03:15:41 PST 2016
Yes Saber this is what i'm being told in irc. And it works. Thanks
pfiuuu! Two days I'm struggling and "googling" things here and there. I
should have asked here earlier
This information needs imho to be available in the
http://htmlpreview.github.io/?https://raw.githubusercontent.com/qgis/QGIS/master/doc/INSTALL.html
instructions
QGIS Community rocks,
Harrissou
2016-12-14 11:51 GMT+01:00 Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk>:
> You don’t have to run “make install” and simply run QGIS after “make” :
> If you cd to QGIS_BUILD_DIR/output/bin/ and run ./qgis
> Cheers
> Saber
> *From:* Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] *On
> Behalf Of *DelazJ
> *Sent:* 14 December 2016 10:40
> *To:* qgis-developer
> *Subject:* [Qgis-developer] Today I almost build QGIS on Linux... but it
> fails
> Hi,
> *Disclaimer*: I'm a long-term Windows user who is learning Linux. And I'm
> not a developer so be patient.
> Before I pulled a request to master branch I decided this time to build
> QGIS and check my changes. I often heard people say "Use Linux; it's so
> easy to do that". And while a year (or more) ago I completely fail to
> understand which version of tools I should install to do that on Windows (7
> or 8), this time it looks very straightforward.
> I followed instructions at http://htmlpreview.github.io/?
> (note that it should be updated as there still is:
> - a section entitled Qt4
> <https://htmlpreview.github.io/?https://raw.githubusercontent.com/qgis/QGIS/master/doc/INSTALL.html#toc4>
> while its content is all about Qt5 and, Qt4 has nothing to do with QGIS 3
> if I'm not wrong
> - a section entitled Qt5
> <https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc12>
> which warns you about using Qt5)
> So, I followed these instructions, regardless Qt4 title:
> - create the same folders at the same places
> - run "ccmake .." indicate the $home/apps folder as destination folder for
> the application (CMAKE_INSTALL_PREFIX)
> - run "make"
> -  and then run "make install", showing many lines that point to my apps
> dir. I get a failure due to right access to some folder (I don't know why).
> So I run "sudo make install" which went till the end with no failure (that
> i can see)
> But when all this finishes tens of minutes later, my home/apps dir remains
> EMPTY. No QGIS to launch!
> If someone has an idea where I should investigate thanks very much. Or if
> you need me provide more information, let me know...
> Thanks,
> Harrissou
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work
> or perform services then our standard terms and conditions
> <http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf>
> shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161214/67a22bfd/attachment.html>
