[Qgis-developer] QGIS Install instructions
Tim Sutton tim at kartoza.com
Tue Dec 20 21:44:10 PST 2016
Hi Harrisou
> On 21 Dec 2016, at 12:04 AM, DelazJ <delazj at gmail.com> wrote:
> Hi,
> Browsing the install instructions of QGIS at http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html <http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html> (whose source is at https://github.com/qgis/QGIS/blob/master/INSTALL <https://github.com/qgis/QGIS/blob/master/INSTALL>), it is stated:
> _/!\ Note to document writers: This documented is generated from
> doc/INSTALL.t2t - if you need to edit this document, be sure to edit that
> file rather than the generated INSTALL document found in the root of the
> source directory._
> The doc/INSTALL.t2t file being an aggregate of multiple .t2t files from the doc folder, I concluded that these were the files to edit if I needed to fix something in the install instructions.
> So, can someone please explain me why this fix (https://github.com/qgis/QGIS/commit/6f87532ac7610f72c1f8bbef7deceb713f7f8e54 <https://github.com/qgis/QGIS/commit/6f87532ac7610f72c1f8bbef7deceb713f7f8e54>) from days ago is not yet available in https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc10? <https://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc10?>
I am not sure if the process has changed, but historically we would only generate the INSTALL document during the release process...I would suggest to just run the t2t script to produce the INSTALL doc when you make changes and then include the updated INSTALL in your patch.
Regards
Tim
> Regards,
> Harrissou
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161221/82d6fefb/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161221/82d6fefb/attachment-0001.jpg>
