[Qgis-developer] Drag & Drop fails on Geopackage
Matthias Kuhn
matthias at opengis.ch
Wed Dec 21 09:20:26 PST 2016
On 12/21/2016 06:07 PM, Giovanni Manghi wrote:
> Hi Matthias
>> I am not sure if there are really more regressions or if these just are
>> spotted more often because LTR are gaining more visibility and hence
>> testing (which is a good sign).
> no, I personally found (for example) tools/features working in 2.14.3
> that are not working in 2.14.9
Which is no indication that the same did not happen in 2.8 as well but
was unnoticed.
But it also means that we still have room for improvement, lucky us :)
>> Isn't that the case already? I always look at blocker priority issues
>> first which are assigned based on these criteria I think.
> I may be wrong, but the during the latest bug fixing efforts the
> regression/high priority bug list was not used as priority list.
It certainly was one factor for me but in the end it's a mixed bag of
- priority
- quality of issue report
If there's no steps for how to reproduce it (in a reasonable time
and with data in reach) I'll stop right there
- expected chance of success
Better to spend the time fixing 3 non-critical ones than not fixing
a critical one
- expected time to fix
Better to spend a day fixing 6 non-critical ones in a day than 1
critical ones in two days
- knowledge of the codebase
if I know that some other dev might be better suited for something,
I'll probably leave it to him
- knowledge of certain problems
if I am experiencing a problem during bugfixing, it's in front of
nose and I will fix it. The next time I might need 2 hours to
reproduce the bug. Also knowing that something is a problem for me
or someone I know makes it rise up my priority list.
Matthias
