[Qgis-developer] [QGIS Server] How to share QgsPostgresSharedData between multiple QGIS instances
Matthias Kuhn
matthias at opengis.ch
Thu Dec 22 04:29:54 PST 2016
Hi René-Luc
> Do you have an idea on a way to share a QgsPostgresSharedData between
> multiple QGIS instances ?
There are different approaches to this:
* Use a shared memory segment http://doc.qt.io/qt-5/qsharedmemory.html
in this case, if the server is restarted, anything will be gone
This might introduce data corruption if someone tries to do an update
with a fid obtained before the restart which collides with a newly
created fid.
* Use some persistent storage like a sqlite database to cache the keys
* Use a reproducible algorithm to generate the fid<->pk mapping
(something similar to qHash)
Regards
Matthias
