[Qgis-developer] [QGIS Server] How to share QgsPostgresSharedData between multiple QGIS instances
Alessandro Pasotti
apasotti at gmail.com
Thu Dec 22 06:48:54 PST 2016
On Thu, Dec 22, 2016 at 1:29 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi René-Luc
> > Do you have an idea on a way to share a QgsPostgresSharedData between
> > multiple QGIS instances ?
> There are different approaches to this:
> * Use a shared memory segment http://doc.qt.io/qt-5/qsharedmemory.html
> in this case, if the server is restarted, anything will be gone
> This might introduce data corruption if someone tries to do an update
> with a fid obtained before the restart which collides with a newly
> created fid.
> * Use some persistent storage like a sqlite database to cache the keys
> * Use a reproducible algorithm to generate the fid<->pk mapping
> (something similar to qHash)
> Regards
> Matthias
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Hi Matthias,
In Lyon we also talked about how to share caches between different server
processes, do you think that the shared memory segment would be appropriate
in that case?
For a cache it does not matter if it's not persistent.
The idea would be to have the server honour the 12 factors patterns.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161222/8e780eaa/attachment-0001.html>
