[Qgis-developer] Dial range widget composer orientation
Régis Haubourg regis.haubourg at gmail.com
Thu Dec 22 08:21:39 PST 2016
Hi dev's
I'm using the dial widget to edit rotation values used to rotate map
symbols.
Is there a way to set default orientation of the widget so that 0 is a the
top. Currently it points to a vague bottom left.
Thanks !
Régis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161222/90b4aef9/attachment.html>
