[Qgis-developer] QGIS3 crashes on startup
Rainer Hurling rhurlin at gwdg.de
Fri Dec 23 09:36:26 PST 2016
Hi Paolo,
Am 23.12.2016 um 16:02 schrieb Paolo Cavallini:
> Il 22/12/2016 09:34, Paolo Cavallini ha scritto:
>> Hi all,
>> in the last few days, freshly compiled QGIS master crashes.
> Solved by cleaning up the entire environment. make clean was not enough.
> Thanks.
Could you describe more exactly, what you did, when you clean up 'the
entire environment', please.
With new master versions on my FreeBSD boxes, I also have some trouble
at startup from time to time. For me, it helps to remove the user
configuration in '~/.qgis-dev' and sometimes also in '~/.config/QGIS'.
Is this, what you meant be 'entire environment'?
Thanks in advance.
Best wishes,
Rainer Hurling
