[Qgis-developer] QGIS3 crashes on startup
Paolo Cavallini cavallini at faunalia.it
Fri Dec 23 09:57:08 PST 2016
Il 23/12/2016 18:36, Rainer Hurling ha scritto:
> Could you describe more exactly, what you did, when you clean up 'the
> entire environment', please.
cleaning up the git local repo
> With new master versions on my FreeBSD boxes, I also have some trouble
> at startup from time to time. For me, it helps to remove the user
> configuration in '~/.qgis-dev' and sometimes also in '~/.config/QGIS'.
> Is this, what you meant be 'entire environment'?
not, I did not touch ~/.qgis3
all the best
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
