[Qgis-developer] QGIS3 crashes on startup
Rainer Hurling rhurlin at gwdg.de
Fri Dec 23 23:23:20 PST 2016
Am 23.12.2016 um 18:57 schrieb Paolo Cavallini:
> Il 23/12/2016 18:36, Rainer Hurling ha scritto:
>> Could you describe more exactly, what you did, when you clean up 'the
>> entire environment', please.
> cleaning up the git local repo
>> With new master versions on my FreeBSD boxes, I also have some trouble
>> at startup from time to time. For me, it helps to remove the user
>> configuration in '~/.qgis-dev' and sometimes also in '~/.config/QGIS'.
>> Is this, what you meant be 'entire environment'?
> not, I did not touch ~/.qgis3
> all the best
Thanks for clarification :)
