[Qgis-developer] Testing new network analyses
Paolo Cavallini
cavallini at faunalia.it
Sat Dec 24 02:25:43 PST 2016
Il 14/12/2016 09:04, Paolo Cavallini ha scritto:
> I am aware of the issue, I tried increasing tolerance, with no results.
> That happened with EPSG:4326; when switching to a metric CRS, it works.
> My interpretation is that setting a too high tolerance, easy for degrees
> (e.g. 1 degree is huge) makes it impossible to compute the path.
> Maybe the user should be warned about this.
I tried again, with a bit more time, and:
* I can compute shortest paths with the two algs
* I cannot get meaningful convex hullsfor the two service area algs.
I'm probably not understanting how the area algs work. Alex, could you
please give a quick explanation, or point to an existing one, and/or
share a sample project and params?
Thanks a lot.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
