[Qgis-developer] New GRASS plugin: a test drive
Radim Blazek
radim.blazek at gmail.com
Mon Feb 1 01:56:36 PST 2016
On Fri, Jan 29, 2016 at 5:38 PM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> I'm updating the Users Manual Figures. In my current installation of QGIS
> master the GRASS Toolbar only features 2 Icons. Is this expected? I can only
> see Open grass tools and Display current GRASS region Icons. We used to have
> Open Mapset, Close Mapset, New Mapset and GRASS options as well.
Yes it is intended. The tools which are not frequently used were
removed from the toolbar to keep UI clean.
Radim
> Thanks
> Radim Blazek <radim.blazek at gmail.com> escreveu no dia terça, 15/12/2015 às
> 11:29:
>> On Thu, Oct 8, 2015 at 10:47 PM, Blumentrath, Stefan
>> <Stefan.Blumentrath at nina.no> wrote:
>> > Finally, I was wondering if it could be an idea to place all mapset
>> > related buttons (open / close / new / change mapset) at the bottom of the
>> > Modules dialogue and to add a "manage mapset access" button, which runs the
>> > mapset picker for modifying the search path (g.mapsets -s) there as well?
>> > One (I if you like) can add g.mapsets with the s-flag as a module (I tested
>> > "g.mapsets -s" in the QGIS-GRASS-plugin and it starts the GRASS dialogue
>> > successfully), but it is probably better to have this option a bit more
>> > prominent (as it might come in handy with the new multiple map input
>> > option)?
>> I have added "Add/Remove mapset to/from search path" as new browser
>> actions in master. There are now also distinct icons for mapset, open
>> mapset and mapset in search path.
>> Radim
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetaswordpress.com
> http://gisunchained.wordpress.com
