[Qgis-developer] New GRASS plugin: a test drive
Alexandre Neto
senhor.neto at gmail.com
Mon Feb 1 03:05:42 PST 2016
Ok thanks.
I will update the documentation then. Because right in the beginning shows
all the icons. I can remove them, right?
Thanks again,
Alexandre
Radim Blazek <radim.blazek at gmail.com> escreveu no dia segunda, 1/02/2016 às
09:56:
> On Fri, Jan 29, 2016 at 5:38 PM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > I'm updating the Users Manual Figures. In my current installation of QGIS
> > master the GRASS Toolbar only features 2 Icons. Is this expected? I can
> only
> > see Open grass tools and Display current GRASS region Icons. We used to
> have
> > Open Mapset, Close Mapset, New Mapset and GRASS options as well.
> Yes it is intended. The tools which are not frequently used were
> removed from the toolbar to keep UI clean.
> Radim
> > Thanks
> > Radim Blazek <radim.blazek at gmail.com> escreveu no dia terça, 15/12/2015
> às
> > 11:29:
> >> On Thu, Oct 8, 2015 at 10:47 PM, Blumentrath, Stefan
> >> <Stefan.Blumentrath at nina.no> wrote:
> >> > Finally, I was wondering if it could be an idea to place all mapset
> >> > related buttons (open / close / new / change mapset) at the bottom of
> the
> >> > Modules dialogue and to add a "manage mapset access" button, which
> runs the
> >> > mapset picker for modifying the search path (g.mapsets -s) there as
> well?
> >> > One (I if you like) can add g.mapsets with the s-flag as a module (I
> tested
> >> > "g.mapsets -s" in the QGIS-GRASS-plugin and it starts the GRASS
> dialogue
> >> > successfully), but it is probably better to have this option a bit
> more
> >> > prominent (as it might come in handy with the new multiple map input
> >> > option)?
> >> I have added "Add/Remove mapset to/from search path" as new browser
> >> actions in master. There are now also distinct icons for mapset, open
> >> mapset and mapset in search path.
> >> Radim
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetaswordpress.com
> > http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160201/e6cf32b2/attachment-0001.html>
