[Qgis-developer] New GRASS plugin: a test drive
Radim Blazek radim.blazek at gmail.com
Mon Feb 1 03:23:08 PST 2016
On Mon, Feb 1, 2016 at 12:05 PM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Ok thanks.
>  I will update the documentation then. Because right in the beginning shows
> all the icons. I can remove them, right?
The actions are still in the menu. I would suggest to keep them and
change the text "...provided with the toolbar menu" to "...provided
with the menu" and add something like "Open GRASS Tools and Display
Current GRASS Region actions are also available in the toolbar menu".
Thanks
Radim
> Thanks again,
> Alexandre
> Radim Blazek <radim.blazek at gmail.com> escreveu no dia segunda, 1/02/2016 às
> 09:56:
>> On Fri, Jan 29, 2016 at 5:38 PM, Alexandre Neto <senhor.neto at gmail.com>
>> wrote:
>> > I'm updating the Users Manual Figures. In my current installation of
>> > QGIS
>> > master the GRASS Toolbar only features 2 Icons. Is this expected? I can
>> > only
>> > see Open grass tools and Display current GRASS region Icons. We used to
>> > have
>> > Open Mapset, Close Mapset, New Mapset and GRASS options as well.
>> Yes it is intended. The tools which are not frequently used were
>> removed from the toolbar to keep UI clean.
>> Radim
>> > Thanks
>> > Radim Blazek <radim.blazek at gmail.com> escreveu no dia terça, 15/12/2015
>> > às
>> > 11:29:
>> >> On Thu, Oct 8, 2015 at 10:47 PM, Blumentrath, Stefan
>> >> <Stefan.Blumentrath at nina.no> wrote:
>> >> > Finally, I was wondering if it could be an idea to place all mapset
>> >> > related buttons (open / close / new / change mapset) at the bottom of
>> >> > the
>> >> > Modules dialogue and to add a "manage mapset access" button, which
>> >> > runs the
>> >> > mapset picker for modifying the search path (g.mapsets -s) there as
>> >> > well?
>> >> > One (I if you like) can add g.mapsets with the s-flag as a module (I
>> >> > tested
>> >> > "g.mapsets -s" in the QGIS-GRASS-plugin and it starts the GRASS
>> >> > dialogue
>> >> > successfully), but it is probably better to have this option a bit
>> >> > more
>> >> > prominent (as it might come in handy with the new multiple map input
>> >> > option)?
>> >> I have added "Add/Remove mapset to/from search path" as new browser
>> >> actions in master. There are now also distinct icons for mapset, open
>> >> mapset and mapset in search path.
>> >> Radim
>> >> _______________________________________________
>> >> Qgis-developer mailing list
>> >> Qgis-developer at lists.osgeo.org
>> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Alexandre Neto
>> > @AlexNetoGeo
>> > http://sigsemgrilhetaswordpress.com
>> > http://gisunchained.wordpress.com
> Alexandre Neto
> @AlexNetoGeo
