[Qgis-developer] New GRASS plugin: a test drive
Alexandre Neto
senhor.neto at gmail.com
Mon Feb 1 03:25:34 PST 2016
Ok, I will do that. Thanks!
Radim Blazek <radim.blazek at gmail.com> escreveu no dia segunda, 1/02/2016 às
11:23:
> On Mon, Feb 1, 2016 at 12:05 PM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > Ok thanks.
> > I will update the documentation then. Because right in the beginning
> shows
> > all the icons. I can remove them, right?
> The actions are still in the menu. I would suggest to keep them and
> change the text "...provided with the toolbar menu" to "...provided
> with the menu" and add something like "Open GRASS Tools and Display
> Current GRASS Region actions are also available in the toolbar menu".
> Thanks
> Radim
> > Thanks again,
> > Alexandre
> 1/02/2016 às
> > 09:56:
> >> On Fri, Jan 29, 2016 at 5:38 PM, Alexandre Neto <senhor.neto at gmail.com>
> >> wrote:
> >> > I'm updating the Users Manual Figures. In my current installation of
> >> > QGIS
> >> > master the GRASS Toolbar only features 2 Icons. Is this expected? I
> can
> >> > only
> >> > see Open grass tools and Display current GRASS region Icons. We used
> to
> >> > have
> >> > Open Mapset, Close Mapset, New Mapset and GRASS options as well.
> >> Yes it is intended. The tools which are not frequently used were
> >> removed from the toolbar to keep UI clean.
> >> Radim
> >> > Thanks
> >> > Radim Blazek <radim.blazek at gmail.com> escreveu no dia terça,
> 15/12/2015
> >> > às
> >> > 11:29:
> >> >> On Thu, Oct 8, 2015 at 10:47 PM, Blumentrath, Stefan
> >> >> <Stefan.Blumentrath at nina.no> wrote:
> >> >> > Finally, I was wondering if it could be an idea to place all mapset
> >> >> > related buttons (open / close / new / change mapset) at the bottom
> of
> >> >> > the
> >> >> > Modules dialogue and to add a "manage mapset access" button, which
> >> >> > runs the
> >> >> > mapset picker for modifying the search path (g.mapsets -s) there as
> >> >> > well?
> >> >> > One (I if you like) can add g.mapsets with the s-flag as a module
> (I
> >> >> > tested
> >> >> > "g.mapsets -s" in the QGIS-GRASS-plugin and it starts the GRASS
> >> >> > dialogue
> >> >> > successfully), but it is probably better to have this option a bit
> >> >> > more
> >> >> > prominent (as it might come in handy with the new multiple map
> input
> >> >> > option)?
> >> >> I have added "Add/Remove mapset to/from search path" as new browser
> >> >> actions in master. There are now also distinct icons for mapset, open
> >> >> mapset and mapset in search path.
> >> >> Radim
> >> >> _______________________________________________
> >> >> Qgis-developer mailing list
> >> >> Qgis-developer at lists.osgeo.org
> >> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> > Alexandre Neto
> >> > @AlexNetoGeo
> >> > http://sigsemgrilhetaswordpress.com
> >> > http://gisunchained.wordpress.com
> > Alexandre Neto
> > @AlexNetoGeo
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160201/4442e4fe/attachment.html>
