[Qgis-developer] Simplify provider side
Paolo Cavallini
cavallini at faunalia.it
Mon Feb 1 03:02:15 PST 2016
Also here it does not seem to help.
All the best.
Il 1 febbraio 2016 11:30:36 CET, "Médéric Ribreux" <mederic.ribreux at medspx.fr> ha scritto:
>Hello,
>I have made some tests at work on an Oracle 11g database on a layer
>with
>indexes...
>It seems that Oracle simplification is worse than direct data access:
>* time for rendering without provider simplification: 10 seconds.
>* time for rendering the same layer with provider simplification: 28
>seconds.
>I've tried to change the simplification threshold but it doesn't really
>change anything.
>Is there a way to go faster than this ?
>Le 2016-01-29 23:41, A Huarte a écrit :
>> Hi, it is true, now only it is implementd in the postgres provider.
>> But it could be implemented easy beacuse of it is entirely similar
>> like the Postgre provider does with the ST_Simplify function.
>> I propose to test a new pull:
>> https://github.com/qgis/QGIS/pull/2738
>> Best regards
>> Alvaro
>> DE: Jürgen E. Fischer <jef at norbit.de>
>> PARA: qgis-developer at lists.osgeo.org
>> ENVIADO: Viernes 29 de enero de 2016 20:36
>> ASUNTO: Re: [Qgis-developer] Simplify provider side
>> Hi Paolo,
>> On Fri, 29. Jan 2016 at 17:35:58 +0100, Paolo Cavallini wrote:
>>> how can I know for which providers does the feature simplification
>> work
>>> server side? AFAIK PostGIS uses it, but what about other DBs, namely
>> Oracle?
>> The oracle provider doesn't.
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> http://www.norbit.de [1]
>> QGIS release manager (PSC) Germany IRC: jef on
>> FreeNode
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Links:
>> [1] http://www.norbit.de/
>Médéric RIBREUX
>https://medspx.fr
Sent from mobile. Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160201/11b974dd/attachment.html>
