[Qgis-developer] Simplify provider side
    A Huarte
    ahuarte47 at yahoo.es
    Mon Feb  1 03:59:24 PST 2016
Uf.... this behavior is observed in other forums:
http://osgeo-org.1560.x6.nabble.com/SDO-UTIL-SIMPLIFY-Oracles-version-of-ST-SIMPLIFY-td5101199.html
The issue 12298 (https://hub.qgis.org/issues/12298) of Michael Douchin proposes the use of SDO_UTIL.RECTIFY_GEOMETRY function.Can be it a good time to test ?
      De: Paolo Cavallini <cavallini at faunalia.it>
 Para: Médéric Ribreux <mederic.ribreux at medspx.fr>; A Huarte <ahuarte47 at yahoo.es>
CC: qgis-developer at lists.osgeo.org
 Enviado: Lunes 1 de febrero de 2016 12:02
 Asunto: Re: [Qgis-developer] Simplify provider side
Also here it does not seem to help.
All the best.
Il 1 febbraio 2016 11:30:36 CET, "Médéric Ribreux" <mederic.ribreux at medspx.fr> ha scritto:
Hello,
I have made some tests at work on an Oracle 11g database on a layer with
indexes...
It seems that Oracle simplification is worse than direct data access:
* time for rendering without provider simplification: 10 seconds.
* time for rendering the same layer with provider simplification: 28
seconds.
I've tried to change the simplification threshold but it doesn't really
change anything.
Is there a way to go faster than this ?
Le 2016-01-29 23:41, A Huarte a écrit :
 Hi, it is true, now only it is implementd in the postgres provider.
 But it could be implemented easy beacuse of it is entirely similar
 like the Postgre provider does with the ST_Simplify function.
 I propose to test a new pull:
 https://github.com/qgis/QGIS/pull/2738
 Best regards
 Alvaro
 DE: Jürgen E. Fischer <jef at norbit.de>
 PARA: qgis-developer at lists.osgeo.org
 ENVIADO: Viernes 29 de enero de 2016 20:36
 ASUNTO: Re: [Qgis-developer] Simplify provider side
 Hi Paolo,
 On Fri, 29. Jan 2016 at 17:35:58 +0100, Paolo Cavallini wrote:
 how can I know for which providers does the feature simplification
 work
 server side? AFAIK PostGIS uses it, but what about other DBs, namely
 Oracle?
 The oracle provider doesn't.
 Jürgen
 JürgenE. Fischer norBIT GmbH Tel.
 +49-4931-918175-31
 Dipl.-Inf. (FH) Rheinstraße 13 Fax.
 +49-4931-918175-50
 Software Engineer D-26506 Norden
 http://www.norbit.de [1]
 QGIS release manager (PSC) Germany IRC: jef on
 FreeNode
 Qgis-developer mailing list
 Qgis-developer at lists.osgeo.org
 List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
 Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
 Links:
 [1] http://www.norbit.de/
Sent from mobile. Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160201/d515b341/attachment-0001.html>
