[Qgis-developer] Interactive raster editing mode
Alexandre Neto senhor.neto at gmail.com
Wed Feb 3 14:36:10 PST 2016
Hello Tom,
AFAIK This is the closest you can get:
https://plugins.qgis.org/plugins/Serval/
Tom Moore <moortom at gmail.com> escreveu no dia quarta, 3/02/2016 às 21:07:
> Greetings
> Does QGIS have any sort of interactive raster editing support?
> Ideally this would be something  integrated in the map display panel
> (not a separate task like d.rast.edit), in order to natively support
> the typical pan/zoom and co-display of contextual data.
> For this application assume that the raster handle provided by GDAL
> supports edits, so persisting the updated values is not an issue.  The
> feature set I would like to have is something like a simple 'paint'
> program:
> - select the layer to edit
> - select the value to apply (select from legend, or eyedropper tool to
> select from raster)
> - select the brush shape
> - use the mouse to 'paint' the changes.
> If this type of feature doesn't exist, then roughly what would be
> involved to implement it?
> Cheers,
> Tom
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160203/2b469925/attachment.html>
