[Qgis-developer] Problems upgrading nightly in Ubuntu 14.04
Jeremy Palmer
JPalmer at linz.govt.nz
Fri Feb 12 11:39:39 PST 2016
> Décompactage de qgis-plugin-globe-common
> (1:2.13.0+git20160212+bcc8e2a+20trusty) sur
> (1:2.13.0+git20160209+964ae1f+20trusty) ...
> Traitement déclenché pour mime-support (3.54ubuntu1.1) ...
> Des erreurs ont été rencontrées pendant l'exécution :
> /var/cache/apt/archives/qgis_1%3a2.13.0+git20160212+bcc8e2a+20trusty_i386.deb
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> 2016-02-12 15:52 GMT+01:00 Jürgen E. <jef at norbit.de>:
I did this to resolve the issue:
sudo dpkg-divert --remove /usr/bin/qgis
sudo dpkg-divert --remove /usr/bin/qbrowser
I think it was related to this change:
https://github.com/qgis/QGIS/commit/8b054e6661c672b10f14afc661bc16ad83c6e064
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
