[Qgis-developer] Problems upgrading nightly in Ubuntu 14.04
DelazJ
delazj at gmail.com
Fri Feb 12 13:44:41 PST 2016
Thanks Jeremy, it works!
2016-02-12 20:39 GMT+01:00 Jeremy Palmer <JPalmer at linz.govt.nz>:
> > Décompactage de qgis-plugin-globe-common
> > (1:2.13.0+git20160212+bcc8e2a+20trusty) sur
> > (1:2.13.0+git20160209+964ae1f+20trusty) ...
> > Traitement déclenché pour mime-support (3.54ubuntu1.1) ...
> > Des erreurs ont été rencontrées pendant l'exécution :
> /var/cache/apt/archives/qgis_1%3a2.13.0+git20160212+bcc8e2a+20trusty_i386.deb
> > E: Sub-process /usr/bin/dpkg returned an error code (1)
> > 2016-02-12 15:52 GMT+01:00 Jürgen E. <jef at norbit.de>:
> I did this to resolve the issue:
> sudo dpkg-divert --remove /usr/bin/qgis
> sudo dpkg-divert --remove /usr/bin/qbrowser
> I think it was related to this change:
> https://github.com/qgis/QGIS/commit/8b054e6661c672b10f14afc661bc16ad83c6e064
> Cheers
> Jeremy
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160212/8a073f1d/attachment.html>
